SWR10 vibrates with "normal" Alarm in Xperia Z2 and doesn't on Xperia Z
profile.country.ES.title
eXPerience83
Member
Why SWR10 vibrates when "normal" alarm sounds on Xperia Z2 and I can use the button to delay the alarm, and this feature is not enabled on Xperia Z?
The "smart" alarm works fine.
17 REPLIES 17
profile.country.RO.title
_alexdon_
It is normal,the SWR10 vibrates with normal alarm too,you can change that from smartband settings.
alexdon
eXPerience83
Member
Can't find that option.
_alexdon_
I have Z1 but there should be like that: first drag down notification bar,tap on smartband,tap on edit settings.You should get more options and you should be able to scroll down.There is a 4th setting called Alarm.Untick it.
alexdon
eXPerience83
Member
My options are (my phone are set into Soppanish language so I translate it):
-night mode
-notificatios
-smart alarm
-out of range alarm
-incoming call
-APPS
-User manual
Tags (1)
SergioPL1
Which version of software are you using? Go into Smartband settings, tap on "I" and host application version. I'm on 1.5.0.488.
I have:
- Automatic night mode
- Notifications
- Intelligent wake up
- Alarm
- No smartband in range alert
- Incoming call alert
You need to add or remove tick in "Alarm" position. It selects if your SmartBand vibrates during the alarm or not.
eXPerience83
Member
- Notifications
- Alarm (I don't have that option)
App version 1.5.0.488
firmware 05.00.12
I have an Xperia Z with firmware 10.5.1.A.0.283, and Android 4.4.4
I tried it with an Xperia Z2 and the "Alarm" option appears, but not on Xperia Z.
Screen shot attached, the smartband is disconnected because I'm charging it.
SergioPL1
I have no clue for that. Instruction manual is quiet about compatibility with Z.
It will require setting up everything from the ground up (I mean Smartband settings and SmartConnect).
1) Go into Settings / Applications / Downloaded.
2) Select SmartBand
3) Force Quit, delete data
4) Restart phone
If alarm is still invisible I would try to do the steps above for SmartConnect app.
eXPerience83
Member
Done, but the problem persist.
Cleared Smartband app and Smart conect and system restarted.
_alexdon_
What if you disable night mode?
alexdon
