SWR10 together with SBH52
kud
Hello,
is threre any way to use the SBH52 for taking a call and the SWR10 for live-tracking at the same time?
4 REPLIES 4
Thommo
Genius
Shouldn't be an issue - I have the SWR10 and the information is stored on the device and only transfered when you start Lifelog and update your stats - I also use that device at the same time as an old HBH-PV702 headset and a new SBH80 and have no issues to report - But I don't use the latter two devices at the same time
kud
thx,
it will be great to realize the vibration during an incomming call and after that I see the number
on the SBH52 and make the call. (this is what I miss on that device)
SergioPL1
You shouldn't have any problems.
I tried to set vibration ON on SmartWatch SW2, SWR10 and SBH80 at the same time. Except it was frustrating experience with all those vibrations at the same time it worked perfectly.
kud
In the mean time I also test both things together. I works.
Now I can reduce the volume of the SBH52 and the handy to minimum and the Smartband is vibrated during a call.
