Basically as in the title. It wont switch on after holding the standby button, I have to remove battery for 1min then insert again.
Also, waking up, unlocking screen doesn't always work first time, the screen brightens up black, but you need to lock it again and then unlock to view the screen.
SI 1268-9795 CB5
TYPE: PM-0060-BV AAB
FCC ID: PY7PM-0060 12W51
I suggest that you try to run a software reinstall using SUS.
If the problem still remains you should contact your local support team, to have the phone examined and fixed at an repair center.
