Hello
Is there any setting in NEO V ICS 4.0.4 to switch between 3g and 2g network. I mostly use 2G network but some i have may have to use 3G network. So i want to know that there is any setting that i just turn 3g and use 2g.
Hi, not sure if the following menu helps ....
Goto Settings>Wireless & Networks>More>Mobile networks>Network Mode and check the available options.
ya in that option only
wcdma only,
gsm only
wcdma(preferred)/gsm
are listed?
Those are the available options .... I think it is dependent on Network Operators, try checking with your Network Operator.
means?
How can i check from network operator?
Contact them.
