there has been a sudden reduction in touch sensitivity of my phone(xperia u). coz of this i am struggling to send sms. is there any way out... phone is under guaranty period
My phone had the same problem, the touch panel is suddenly not sensitivity enough.
I take my phone to the service center, and replace a touch panel...
It would be worth trying to run an update/repair first and if this does not resolve the issue then please do follow the advice of Heresy.
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
Try removing the Screen guard that was on the phone originally! there was an issue many users faced this problem but solved it once the stock screen guard is taken out! worth a try!
