stuck at boot screen
ZhGoh
Hi, When i try to turn on my Xperia SL, it stuck in a boot loop. The device reboot after the screen shows the SONY and XPERIA logo, and the same things happen again and again. Please help me, how to solve this?
Tags (1)
3 REPLIES 3
Thommo
Genius
You can try holding volume up and power button until you feel 3 vibrations 1 after the other - Not 1 on it's own 3 will come soon after, Then try to boot your phone, If that fails then you will need to run a repair using either PCC or SUS found here install select phone and follow the on screen instructions
ZhGoh
the PC companion said that windows 7 or previous version is needed to update my phone, windows 8 cant do it? BTW is there any way to get into recovery mode of my phone?
Thommo
Genius
There is no recovery mode for the Xperia S however as your running Windows 8 have you considered or are you aware that you can install a free program called VMware Player which will allow you to install a virtual XP operating system thus allowing you to run programs like PCC or SUS VMware Player is free for personal use so scroll down the page if you are interested,
