after i update to 5.1.1 i got a lot of problem with sound and black screen so i go back to 5.0.2 but the only problem i got now is a low space on the internal storage , i have about 5g free space and i still got the message , i connect the phone to lap and it's same too have 4g free space , i have no cached data and i have no external storage
any idea
How did you downgrade and if you used Flashtool did you tick the boxes for User data and cache in the top right corner
i use flashtool but i don't tick them !!!! this maybe the problem ?:smileyexclaim:
You should have ticked them so now you are getting wrong info
Edit: doing so will factory reset your device so backup what you need
no need to go back
i go upgrade to 5.1.1 back and the problem with sound at incoming calls still on
so i just do what i found in the forum i enable developer mode and off use awesome player instead of Nuplayer
the problem of sound is in awesome player , sony should make it a default Nuplayer
the problem of space gone :smileysmileythumbsup: and i notice another thing when i downgrade i restart the mobile i got 325 app and every restart the mobile read them again , when i upgrade at 1st open i got 218 only and when i restart mobile don't read them again
So the issue was an app and not Sony
if you speak about incoming calls problem sony should make Nuplayer ( like in 5.0.2 ) as a main audio playback so ppl don't go to developer mode and play with it
there are notes about new update
- black screen when trying to use home bottom
- the gab between the power and the network ( u can see them in the picture i upload from 5.0.2 and 5.1.1 ) and the gab still on when u charge ur mobile ( not designed for charge )
- when u got a call and if you use the dial pad to write a number the caller give it to you , you can't remove a number you write by mistake or correct it ( ex: 165344892 u can't go back between 44 and put 5 ) there is no backspace or u can't tap the screen
if you speak about space error , it's my problem i was not aware of what i should mark or maybe the framework
@engmohamed1987 wrote:- when u got a call and if you use the dial pad to write a number the caller give it to you , you can't remove a number you write by mistake or correct it ( ex: 165344892 u can't go back between 44 and put 5 ) there is no backspace or u can't tap the screen
Nice point you made, same thing in my Z1C v5.1.1. Though I never checked this in older firmwares.
