Hi.
How can i use the standardnumber from a contact to make a call without getting the full list of all numbers of the contact?
Thank you in advance.
Wautschi
I don't understand exactly,so you have more numbers for a contact and you want to select a number?
If you on about having more than one number associated with a contact like mobile, work and home then you can't unless you were to create a new contact for each number so for example Ben work then Ben home etc etc
