Hi
Everytime i turn on stamina mode it doesnt make any difference at all with the feature off. I noticed this problem yesterday as i heard my phone vibrate for a bbm message. i dont have any apps added on the white list but i still recieve all massages and notifications as normal without stamina mode activated.
When i activate stamina mode it says estimated time for battery is 18 hours and when i turn it off it says 7 hours. And with the stamina mode activated my battery lasts about 7 hours anyway. i really love this phone and dont want these small problems putting me down 😞
I also went to battery usage in settings and it showed that my phone has been awake the entire 10 hours since i unplugged my phone and stamina mode was turned on the entire time. My phone is now on 15% without me really using it. my screen has been on for only about 1/15th of the time while my phone has been awake the ENTIRE time.
Please let me know if you have an idea how to fix this, thanx 🙂
You could try to reset stamina like this: first disable it,go to settings-apps-all-eco mode controller,force stop and clear data.Restart your device.
i did try that earlier in the day and didnt work. just tied it again now and also didnt work?
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
i will try that tomorrow. only problem is our computer **bleep** and i cant even connect my xperia with the computer. so i will try installing pc companion tomorrow. keep posting if anybody finds more solutions, thanx!
Good luck.
Hi
I'm trying to connect my phone with pc companion now and i want to backup my music on the computer. when i click on backup on my computer and i connect my xperia with the USB it just keeps loading (making circle) and doesnt do anything. i want to back up all my data before doing repair.
Try myphone explorer instead.
Dear alex
I have the same phone and same problem. But even after repair it didn't work again. Problem begins when I install mobilego. When I turn on STAMINA, after a while in standby a notification says mobilego doesn't let STAMINA work properly, and when I tap on it, it brings mobilego app for uninstall. After two time I accidentally tap on "got it" in notifications and STAMINA mode didn't work after. even after all the works.
