stamina mode bug 10.3.1.A.2.67
macdobols
Hi dev team,
Im experiencing a bug in my z's stamina mode. Every after charging my phone the bug occurs. I'm dead tired of force stopping the extended battery app and resetting my phone everytime just to fix the bug. Would you know the root cause of this and kindly advise a corrective action for this.
To other users, do you experience the same kind of issue? Pls share you thoughts on this. Thanks!
5 REPLIES 5
xperiaz2
Which bug are u referring to?
macdobols
To elucidate, my playstore works even if the screen is off (stamina mode on, playstore not included in apps active when standby) which should not be the case when stamina is active. Also it shows that the num of days is only 2days and xx hours compared when the extended batt was reset (4days and xx hours).
There's an app triggering it, keep in mind the more apps that you exclude from STAMINA the less effective it will be
macdobols
Thanks for the advice. What could be a permanent reason for this? I thought this bug will be resolved after the update but i think that's not what happened..
macdobols
*permanent solution i mean...
