After I updated from 5.0 to 5.1.1 I'm experiencing major prblem with battery life (see other thread). I'm now realizing that I'm having some troubles with the stamina mode (but this doesn't entirely explain the problems with battery life.
I have activated stamina clock but data and wifi is always on when I turn on the screen without unlocking my phone. Is anyone else experiencing this?
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Factory reset hasn't helped
A factory reset isn't the same as a system repair
cant you clear the cache in the apps menu, thats what i have done before.
