st15i camera problem after ics
Hi everyone. I bought a new update on June 16. however, a significant reduction in image quality encountered after updating. I went back to the factory settings, reset your phone, I did install the firmware again, but the problem is resolved. if it was not clear, such as pictures taken in a smoky environment. After all did not understand, but the result of a long struggle back to the old software installed and the problem solved. I installed 4.0.4 again. I saw the problem still continues. I went back to 2.3.4 again. :). I mean, think before you install the latest update. I'm sorry for my English. good day everyone. thanks google translate ...
5 REPLIES 5
phoenix_786
The image quality is set as 3mp as default try setting it to 5mp and see if it improves.
Petter
Enthusiast
Good point by phoenix_786, check it out! Slightly_smiling_Face
yes, I know. I checked all the settings and changed. 4.0.4 all works fine except the camera. I checked every place I used the new software in two days. I returned the old software just did not like the quality of photos.
Petter and phoenix_786, increasing resolution also increases noice. Reducing resolution reduces noice. So, on 5mpix setting there would be even more noice than on 3mpix. You should know that. Regards.
phoenix_786
Have you tried a third party camera app.
