speakerphone
MartinH1
speakerphone
Hi, The speakerphone on the Experia Z is not really loud enough for use in the car. Is it possible to play calls through the car radio (I have a Sony CDX DAB700u)? If not what are the best solutions? Thanks, Martin.
4 REPLIES 4
Edison1
If your car supports bluetooth then maybe.
If not, but your car dock supports a 35mm audio jack, then I suggest you connect your Xperia Z to your car with a auxiliary cord. Yes, calls work.
MartinH1
Thanks I'll try the aux cable, will report back.
MartinH1
Hi, The aux cable works well thanks. You have to switch the radio to the aux input of course. Also you musn't put the phone on speakerphone! Apart from the hassle of plugging in the cable it is brilliant. Cheers, Martin.
Terrik
I've done the same thing, but my AUX cable doesn't work with Xperia ZR, and works with my wife's iphone. What's the problem? What should I do?
P.S. Headphones works.
