help , speakerphone z3 does not work when you connect or receive calls.
That is odd, however as it is working in Safe Mode that does narrow it down to a potential software issue/conflict. It would be worth trying a firmware repair in this case:
Please note that performing these steps will delete all user data except for your media files (photos, music and video).
If your handset is able to be powered on and unlocked you can follow the below steps to back-up your personal data prior to running the repair.
Backing up your handset
To back up your phone using PC Companion
1. Go to Support to install PC Companion on a Windows computer.
2. When installed, start PC Companion on the computer.
3. Connect your phone to the computer using a USB cable.
4. Click Start under Backup & Restore.
5. Follow the on-screen instructions.
Exactly what contents will be backed up may differ depending on phone model.
You can view detailed information about this as you follow the steps in the Backup & Restore wizard.
Running the software repair
Before you start you have to download the PC Companion software and install it on your PC.
Once installed on your PC, double-click the PC Companion icon on your desktop to start the update.
Please ensure your phone is powered off and not connected to the PC when you begin this process. You are not required to connect the phone until after step 10.
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
