speaker problem
brenandgr
speaker problem
I currently using Xperia z..when I do water resistance test,the speaker cannot function normally..it's state that  Xperia Z is water resistance..wht
should I do?help me plz
2 REPLIES 2
Er_Kannan
Do you mean that you tried to test the water resistance and the speaker is not working properly after that or are you telling speaker is not working properly underwater?
Alexander1
If you had your phone in water recently there might be some water blocking the speaker making it sound lower then usually. This normally get's better as the water disappear after a few hours.
