Speaker Issues
Plasmid
Speaker Issues
For no Reason the Speaker has some Volume issues.
Its really anoying because it super low volume even when its on the highest level.
What can I do? I saw a blog where someone told, that this issue goes away by itself but im waiting for 3-4 days now.
I hope you understand what i mean and sry for my bad english
greetings.
2 REPLIES 2
Samuel1
Hero
Have you tried de-activating Clear Phase (settings > audio) to see if it suits you better? Also check the additional settings under Call settings (equalizer,  noise cancel etc).
TheEntelexia
Explorer
Did you wet the phone at all? Or may it have got wet without you noticing?. If so, you could have water trapped in the speaker which is safe but you need to let it dry out. You could try blowing on the speaker to loosen the water particles and dry it that way, using a vacuum, using a hair dryer on the lowest setting directed at the speaker or the trusty, container of rice option. This was draw out any moisture in the speaker.
Is the sound from the speaker distorted in any way or simply low volume? If its low volume, I'd say water has entered it, if there is distortion something more hardware related is going on.
Is it just the main speaker or is the ear speaker being affected too?
