SP
MDIHRANA
SP
My phone is resarting continuosly for 10 min. what can i o please help me.......
6 REPLIES 6
Turn it off > connect it to a wall charger > let it charge for 1 hour > repair it with SUS
MDIHRANA
it has charge about 90%. its not turned off,its restarting continuosly.......
Danial-mach1
Leader
As uliwooly said You must perform software repair..in order to perform this with Sus you must turn your phone off install sus on your pc and follow on screen instructions
Jake-SonyXperia
@ MDIHRANA,
To turn the handset off, hold down the Power Button + the Volume Down button until the handset vibrates 2 to 3 times, this will turn the handset off. Once this has been done, download and install the Update Service.
Update Service:
Follow the on screen instructions and perform a software repair. Make sure the handset stays off.
I hope this helps.
What are your thoughts about this forum? Let us know by doing this short survey.
MDIHRANA
Thanks ..... but  I have shut it down by pressing the back side  OFF key for 5sec,then it vibrated 3times and shut down. Should i give it 4.3 again?? cz after updating to 4.3 i m having so much problem. I have updated it by flashtool. My pc campain is saying that it wont work on W8.1. What can i do??
profile.country.RO.title
_alexdon_
Download sony update service instead:
alexdon
