Hi, my XSP has a big problem. Sometimes when I unlock my device, something starts to touch my screen. It happens usually while texting. I can't write because the phone do the "ghost touches". Glove mode is OFF. Other thing is that multitouch is not working all the time. It starts working only when I restart my device. Restart with "ghost touches" didn't help. Please help! Sorry for my bad English
Do you have a screen protector?
Try the hard reset.
Try to update the firmware and phone.
And start the phone in save model to check if it caused by 3rd app.
If that happens only when you are charging it or when it's plugged into a laptop pc, low charger output or non-grounded usb output might cause the problem. Software repair does not fix these. You should use the original charger and try not to use it while plugged in to a pc.
Sometimes when your thumb is too close to the screen it can be registered as a touch input, even your palm can trigger these. And yes this happens even when glove mode is off. But it is not as intolerable as you've mentioned. I suggest you turn on the glove mode and just reboot your phone.
Also safe mode:http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
