SP music playback problem
geordiefatbloke
I occasionally get an issue when playing music, via both the walkman app or another third party app (poweramp). Selected song plays fine for about 15 seconds, then stops and will not play for up to a minute, and then starts again where it left off. Once song has finished, next song starts, and exhibits the same behaviour. Switching the phone off and on again *sometimes* sorts this out, but not always. Suggestions?
Thanks in advance,
Paul
5 REPLIES 5
Alexander1
Do you have the songs stored on the SD card or the internal storage? Do you experience any difference if you move the files from one memory to the other?
Do you experience the same problem in safe mode?
geordiefatbloke
Hi, As for my photos, they are on the SD card. I will try in safe mode. Although its intermittent so hard to reproduce.
geordiefatbloke
Hi, I do experience the problem in safe mode. However, listening to music saved on the phone memory doesn't seem to show the same problem.
Alexander1
Perhaps you have a faulty SD card. Try to format your SD card or try with another SD card in your phone.
geordiefatbloke
Hi, the sd card worked fine with last phone(xperia play), but I'll try reformatting it. Thanks
