Hi all
i have a weird problem with my sony z3, first the screen is freezing the picture but the touch is working, i can hear the tone when i press it
and then its blacked out, so i have to reboot the phone, and it just keep weireder, when i trun off and trun it on again, see the below picture for more details
i put the phone i a back of rice for two days, the same issue, and after sevral attemps of turning the phone off and on, it works like nothing happen, BUT when i turn it on, the down area is less that the first time
so i totally dont know what is this and why this is happen, does anyone facing the same issue or just me?
That seems to be a hardware issue, you could repair the phone with PCC but that will only repair software related issues, contact your Local support to get your phone inspected
Bridge (for Mac)
thanks for your replay
ok do you think that if i replace the screen, it will be solved?
hmmmm
the problem back again, i want to know what is the problem so no one can fraud me when i send for repair
what else can do from my side??
thanks
ok its just keeping weirder
i'm uploading a video that shows when i turn it on and shows the flicker problem and the black out
the weired thing that the phone screen (by it self) appear like nothing happen, and when i turn the phone off and on, the flicker is GONE.
so is the problem solved or what??
and i did not know how to use the PCC to fix the phone.
and for the safe mode, i followed the instructions but it did not booted in safe mode
thanks
ok the flicker is GONE
HOW???!!!
well i dont know for sure, this what i did, and i dont know if this procedure fix the problem
the flicker problem as i said happen randamly, so i have to turn off and turn on again in order that the flicker gone and its work in some cases, so when i manage to see the screen, this is what i did
i notice that when the SIM card in put back, the phone start to act slower for a moment, when i press the off/on botton, the screen take seconds in order to show, so there is a short blackout.
so i dont know if its a SIM card problem issue that made the screen flicker.
and thanks uliwooly for your advice of using the safe mode
thanks
