Hi!
I have a problem, because of that my phone had contact with water the screen is not working. Is black and nothing is happening, I can turn it on and make photos, but I can't see anything and screen is not working. I need to import all contacts and rest of data to the computer, but! When I try to use Xperia companion it shows that "folder is empty" and I need to switch "mpt mode" because the phone is blocked. But I can do anything because screen is black!
Please help me
You could buy a 5-pin MHL adapter > connect the phone to a monitor/tv > restart the phone > check if you can see the menu, if you can and the touchscreen it's responsive then you just have to tap on it whenever you connect the phone to a computer
Or just connect the phone to a computer > the option should be about the height of the power button
I was trying to tap the screen in that place but nothing happens
I need to buy that thing and try to do that. Thank you! Hope I will fix it
so the touchscreen doesn't work? you could test it by calling the phone and then try to slide to answer.
I was trying that, not working
That's not good, I'll see if I come up with something else, does the phone has a password or pin lock or pattern?
no, I just need to slide from middle to the right
