I have a Sony xperia U phone .. there is a Problem in Date & Time function (pic) .. want to konw a way to fix this problem!!
I tried to update my phone using Sony PC Companion .. but It didn't work ..
needd HELP ....
thank uuuu ..
I'm unsure what seems to be the problem. You don't know to set the date?
You can scroll up and down on the values to select Apr / 6 / 2013
Per instance press the Mar and pull it up/down - this way you change the month.
The Problem is ..
sometimes It repaets two numbers .. ex - 7 (pic - there are two 7 numbers)
and It chanages with Time ...
Tried to update .. but PC companion Says " no new updates available "
I'm so blind :smileygrin: Now I see it show 5 7 7 .
When you go to PC companion, use the Repair to repair the software on your phone.
Go tu update, when it says you already have the latest software, press Repair my phone.
This will delete all your apps and reinstall your current software, hopefuly without this bug.
I tried ..
but It didn't work either ...
It says " you already have the latest software ... try again later ... "
I used " Sony Update Service " too ... didn't work .......
don't know what to do ..............
On the same message where it says you already have the latest blah blah there is a button named "REPAIR MY PHONE". Use that.
I tried this (Repair) link .. but .....
then I got msg like this ...
You can always try the same thing with Update service, or just reset your phone to factory settings in settings
I did ... all
I reset my phone .. reset factor data setting! .. reset settings ...
tried to update .. and tried to repair ... using Sony Pc companion & Sony Update Service ...
but none of these worked ...
flash firmware with flashtool.
