Hi All;
I am facing echo problem while out going Calls.The others at receiving end able to hear their voice twice.
Can you suggest me a solution to fix this problem or suggest me to replace device?
Thanks
P.Vijay Sai
No way you can fix this issue. Many are facing the same problem in this phone.
This is a common issue with the phone.
Go to service center and start fighting with them. Then theny will issue a DOA to you. Using that, you can purchase some other phone from the showroom you bought this phone.
I faced the same issue. I tried again a Tippo thinking this might be a rare issue. But in that piece also I faced the same issue.
Now I bought some other brand phone.
Thats the way for you also.
See original threads here on the forum about this and for more information.
