hi i had a pattern lock on my sony before i factory reset it and once i turned it back on again it asked me for a numbered code and obvs i dont know it has any one had this problem ive tryied everything hard reset that number thingy but nothing happens and it isint asking for a google sign in ? any clues
You need to perform a system repair, This is your only option - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
