I have not had any problems aside from the 4.3 common issues until yesterday.
I put my phone into power saving and stamina mode, it was at 3 percent when I put it on the charger and in the morning it was the same. Taking the charger out and putting back in started a Sony logo rebooting cycle.
Attempted the usual comments, off button under battery cover, vol down+ power button. None has helped. I am on a trip in a foreign country without access to a PC.
are there any solutions that do not have android relying on a PC (which it aims to replace) in order to fix this. Thanks in advance
Do this: remove the SIM card,connect it to wall socket and charge it for at least 2 hours.After that,force it to turn off with the button on the back and turn it on normally.
Thanks alexdon, I will update post with verdict in 2.5 hours 🙂
Ok,good luck.
Hi Alexdon,
Went with your suggestion but it did not work. Phone cannot power on at all off of the charger, while plugged it continues to do the sony loop and the illumination bar stays red. Attempted voldwn+power and also softpress off button in the back. This phone was working perfectly fine before i enabled the power saving options. Any other suggestions?
Hi Nikhil,
Unfortunately the phone does not stay off. As soon as i plug in the charger it starts the reboot loop without any input on my part. I have not been able to turn it off completely through any methods.
Remove the SIM and try again.
The sim has not been in the phone since yesterday morning
You should check if there isn't a sony store around you,maybe they can help:
