Sony Xperia S home launcher works on the Arc
xperiablog
http://www.xperiablog.net/2012/02/25/xperia-s-home-launcher-and-widgets-leaked/
Xperia S widget
http://forum.xda-developers.com/showthread.php?t=1526182
Included in Xperia S zip file:
Home.apk – Xperia S home launcher
SemcMusic.apk – Xperia S music player
SemcCalendar.apk – Xperia S calendar app
livewallpaperearth.apk – Animated 3D globe live wallpaper
WidgetPicker.apk – Need if you want to use one of the widgets clock or On/Off
ClockWidget.apk – New clock for homescreen
MusicWidget.apk – New widget for music player
PhotoWidget.apk – Animated photo widget
OnOffTools.apk – New widget with shortcuts
WeatherWidget.apk – Animated weather widget
124 REPLIES 124
Here is an alternative
Thanx XDA Forum
http://forum.xda-developers.com/showthread.php?t=1448552
the music player's UI its quite nice BUT it doesn't have an equalizer
slimshaddy
Hero
but equaliser was mentioned somehwere:smileyconfused:
there's probably a way to port the equalizer or at least the Arc's equalizer. At least we can go back to the original music player by uninstalling the update
I'll just add this here for the n00bs Dizzy_Face
Settings -> applications -> manage applications -> all -> music -> uninstall updates
The live wallpaper its quite interactive
tap on it to zoom in/out
touch the globe to rotate it left or right
KinG
how to flash the phone to install it is it?
KinG
ppls teach me...i wanna try it Slightly_frowning_Face
How to sideload apps
1st Method
How to install it
You need to
download IO File Manager
download the app on your computer, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
2nd method
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
3rd Method
BOX and upload the apks from any computer
install the App on your phone -> open BOX -> tap on the app -> install it
4th Method by far the easiest
an even Easier alternative
download the app, transfer it to your SD card
Download Apk Manager
https://market.android.com/details?id=com.magmamobile.app.apkinstaller&hl=en
open "Apk Manager" and voila select the apps that you wan't to install
Make Sure to mark the Correct Answers & Helpful Answers
its quite simple just follow the steps above. the easiest way to install them is using method 4
