sir when i turn on any services on my accessibility services the phone becomes unresponsive with very late touch detection etc. so sir plz tell me how to deal with this issue...
Do you experience the same problem if you start your phone in safe mode?
If the problem remains in safe mode I suggest that you update/repair your phone software using PC Companion:
sir the same problem in safe mode also and after re installing the software with pc companion the same problem plz help...
and thnx for reply.
I suggest that you try to remove your SD card from the phone to see if that can interfere with the phone.
If you experience the same problem you should have the phone examined by a service center. Please contact your local support for more information:
a few days ago many users including me getting errors in twitter timescape features like the app is opening but showing white screen ,but today I got new error it says SSL require. what is this .. please tell a solution...
