Sony Xperia L Speaker Problem
argel
i have a XPERIA L and i have a problem with its speaker Slightly_frowning_Face i cant play any music, no sounds for the applications and no internal speaker during call but when i turn on the loudspeaker its working i only happen when i updated it on 4.2.2. i reset it in factory mode sett. and i also booted it in safe mode but i doesnt fix the problem  Slightly_frowning_Face can anyone help me on this problem? please Slightly_frowning_Face
7 REPLIES 7
alexrx
Enthusiast
Hi there,
Repair the phone using Sony Update Service.
Cheers.
alexrx
Enthusiast
....Also you can try to test your speaker.
Dial *#*#7378423#*#* > Service Tests > Speaker.
manjuboyz
Hi argel
>you are not able to hear musiq on earphones ?? right
>how about when you get call would you able to hear anything from that ??
>try using different earphones and check whether you are able to hear any sound from your phone, if you can able to hear sound, then problem might be with the earphones, else try to restore the phone once, that may fix your phone problem
Manjuboyz Slightly_smiling_Face
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks Slightly_smiling_Face
manjuboyz
Hi argel
>I can give you few tips since this is the way i use my phone and battey back up is amazing!!
MYPHONE
>Neo V, brought 2 years ago, updated once
>battery back up normal usage 2 COMPLETE days, where i charge my phone daily for 1hr max (60% to 90% will charge by that time)
USAGE
>daily 4 to 5 hrs of music
>60 txts, many whatsapp
>decent calls
>everytime internet enabled atleast for 18hrs
I charge my phone using wall charger,  it gives very good back up, you can try this, it might work for you too Slightly_smiling_Face
let me know if you have any queries
NOTE:
argel
i already reinstall the update but no luck the speaker is not working while playing musics and no internal speaker while having a call i need to switch on the loudspeaker to hear a voice. but when i use earphones everything is ok Slightly_frowning_Face
i dont know what to do Slightly_frowning_Face i already did all things that might fix the problem Slightly_frowning_Face heelp helpp
argel
its working with earphones bro Slightly_frowning_Face
alexrx
Enthusiast
Hi argel,
Sorry to hear that, contact your local Sony Xperia Care for assistance.
I wish you luck.
