Sony Xperia J, Camera and flash stopped working in just 6 month, auto restart
Xperia_J_user
After 6 month from purchasing, My sony xperia is started giving problems:-
1) Camera and flash both are not working, "Camera stopped working", Tested by Xperia diagnosis app also
2) Phone suddenly restarts in between
3) Battery automatically get discharged from 90% to 5% in just 2 hrs
I tried factory restore...I had latest version of android...nothing is working... Slightly_frowning_Face
Anyone is having the same problems?? any suggestion?
2 REPLIES 2
Cot88
Enthusiast
Did issue appeared after a software/firmware update?
Did you try a firmware repair with Sony PC Companion?
If yes and issue is the same in factory condition without any app installed probabily there is a motherboard issue.
So i suggest to go to a Sony service center
Xperia_J_user
No updates were been performed...
I tried factory reset and everything.. Finally went to Xperia Care....
After 2 days, I received the call saying that "this will not be covered under warranty bacause we have seen water drops inside"
Cost : 8000+
I was having this problem ("Camera not available") from long back....just afer 1 month after owning mobile...
Dont know..about Sony's Hardware...but they found good reason for their bad design/bad hardware...
Search on google.....u will found 1/10 xperia mobile having the same problem...
