Hi, please help. My friend reformat my phone. This sony Xperia c3. After that, he reinstalled some of the internal apps of this phone and I don't know why are they. He reinstalled it to reduce the internal space to keep from the storage for being full. Now here's the case, when I was about to change my wall paper and was about to input photos on mu contacts from my album, the dialog box states that "unfortunately, processing com.sonyericsson.com has stopped" And I cannot edit the photos. Please help thanks a lot.
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
