Sony Xperia Battery Only Lasts For 3 Hours
BamBoozle
My new xperia T, which I only had for about 2 weeks, has a really bad battery life. It only lasts for 3 hours after full charge and I need to fix the battery somehow.
How can I fix it?
I can't replace it and I can't show screenshots of it.
Cot88
Enthusiast
You must tell us how do you use your phone.
If you are using your phone for 3 hours for playing high end games or surfing internet with 3g connection probably  is normal.
If battery drops in standby there is an issue
Check also if your phone overheats in idle (standby)
You can also load android in safe mode (with only stock apps) and check battery life
  • Turn off the device.
  • Press and hold down the power key  until the phone vibrates.
  • Wait until the Xperia™ logotype disappears.
  • Press and hold the volume down key. The device then restarts in safe mode.
  • To exit safe mode, restart the device.
