after upgrade to 4.3 sony select won't start it always show this msg "No network connection" i did repair using SUS and Format Reset and cleared data and chache and nothing changed any help ?
Has it worked before? it could be a temporary issue.
i didn't try it before when i was using 4.1 but after 4.3 it won't work
How are you accessing the application, via WiFi or via Network data?
Sorry for the inconvenience.
via 3g network data
Try doing a settings download to the device.
Menu > Settings > Xperia > Internet Settings > Accept Disclaimer > Choose network carrier.
Once the settings have downloaded try access the application.
I hope this helps.
If you go to settings-apps-all-sony select,force stop and clear data,how is it?
