Sony Experia E Dual
hemantgupta14
Sony Experia E Dual
I have bought this phone on 12th march i installed only two game temple run2 and crcicket champian but they are very hanging now i unistalled temple run 2 but phone is still not responding my phone i heating to much please solve it heating problem.
4 REPLIES 4
manjuboyz
Hi Hema
The Phone Ram is 512MB i believe rite ?? and if you play a game which has high end graphics then it lags the speed of game along with heating up
if you want to check availability Ram available then you can go to
Settings -> Apps -> Running -> then at the bottom you can see available Ram memory, will be less i believe in your case, so to increase the ram memory, try this
>settings -> apps -> running -> there you can find many apps running(not the preinstalled from phone) , tap on such apps and try to stop the background process which gives you more Ram, which help not to lag the phone
let us know
Manjuboyz Slightly_smiling_Face
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks Slightly_smiling_Face
Danial-mach1
Leader
for unistalling any app goto setting>apps>downloaded
tap on an app you want and then tap on uninstall
and your phone is branded new...heating up is normal for 1-2 weeks..after that it will fix by it self
hemantgupta14
I also tried you told in this solution,but  phone  still is heating.
profile.country.RO.title
_alexdon_
Boot your phone in safe mode,see how it goes and if still heats up:
alexdon
