Sony Ericsson (CK13i) txt
When you enter the menu and select "Opera Mini" will not run this application. That is, just do not respond to pressing the "Select". Why not?
12 REPLIES 12
Aimee
Enthusiast
Did you download the application to your handset or was this already pre-installed when you purchased it?
What do you think about this forum? Let us know by doing this short survey
Hello!
The application "Opera Mini" was preinstalled on your phone.
Markus1
Leader
Have you tried to restart the phone?
If yes, and not helping:
When did this problem start? Any other apps not working?
Yes, I rebooted the phone, but it did not help. This problem started immediately after buying the phone. All other applications are working.
Markus1
Leader
I suggest you download, install and run Update Service.
Use this software to either update or reinstall the software since something seems to be not working with the software. The pre-loaded apps should of course work and doing this will hopefully make sure they all do so.
Thanks, I'll try to do what you recommend.
Unfortunately, reinstalling the software did not help. Pre-application Opera Mini still does not start.
Markus1
Leader
Sorry to hear that. Since this did not help you need to hand in the phone to a service center for examination and repair.
Contact your regional Sony support for more information on how this is done.
Anyway, thank you!
