hi my sony ericcson x8 is stuck on a boot loop/bricked how do i reset my phone ive tried the sony ericcson update tool and pc companion but neither of them are working
this happened because of a recent program install idk,but is this problem covered in warranty as i bought this phone only a few days ago.
take out the sim and sd cards, then try to use Update Service, it should solve the issue
now, where you trying to root or flash your phone with a third party "flasher" or firmware? if you were, you could just re-flash it and it will be fixed
remember that rooting or installing other firmware voids your warranty, but you can always reset it to its original state
if you did use some other software to update your phone try flashtool
How to flash a custom firmware to your X8 with a flash tool
To flash a custom firmware, you need your phone with the latest version of Android 2.1.1, follow the previus steeps to update your phone. When done, follow this steeps.
The great custom firmware for X8 at this moment is Cyanogen Mod
for mini, exist a version with Froyo (2.2), GingerBread (2.3) and HoneyComb (3.0)
With any of this firmwares, you need to update with xRecovery installing update.zip from SD Card
To update, you need:
Cyanogen mod firmwares:
To install the custom firmware follow this procedure:
i was trying to use PC companion to repair my x8 when i press the back key while connect USB cable,my computer was not responding and force me to restart the computer...why??
Try using Sony Ericsson Update Service (SEUS) instead Aino™ - Update Service - Downloads - Mobile phones - Support - Sony Ericsson ignore the Aino bit, you select your phone once downloaded and you start running the program. It is oftern more succesful that PCC.
Pls any1 out dere should save me pls i wanted to help someone update his xperia x8 thru pc companion but wen d updatin was goin on d cable removed and d fone stop any tym u on it it wont on and it ll just dispaly one ? On d screen d owner will soon come 4 it am dead and d bad part is dat d pc companion was unistalled i am stil a student where do i get d money
http://dl-www.sonyericsson.com/cws/download/1/110/61/1315209439/Update_Service_Setup-2.11.9.6.exe
Hey thanks a lot man!!!!!!!
anytime
thanks for your link, that link is exactly what i need
