Some question
SZLevente
Some question
Hi
In 5.1.1 D2303, there is no Sony select, switch widget, and hidden option in launcher?
The update center's apps update moved to What's new app?
And one heavier question, in home launcher there is shadows in the navigation and notification bar.
It's from system ui, or from the launcher? And it's an image? Can somebody tell me that image name?
(i want to make it full transparent with photoshop, if it's an image.)
5 REPLIES 5
Thommo
Genius
Regarding all your questions - This is the way it is now - updates are done through What's new and the shadows is a UI design
SZLevente
I know it's a design, but i want to remove it.
I imagaine it's an image in the apk, but i didn't found it yet.
And why sony removes Sony select?
Tags (1)
Thommo
Genius
You can't remove it unless you want to recode the whole system UI and Sony select you could try side loading it
SZLevente
If it's an image inside the apk, we just need a root explorer to excract it , edit the picture, and pack it again Slightly_smiling_Face
Thommo
Genius
I doubt it's an image based on the Google code and how the Z axis works giving depth to images making the Ui appear to have different layers
