Some problems
yassoor
Some problems
Hello
I have a few problems with the Sony device:
- the first : my computer could not connect to the Sony p.
After download software (pc companion) I am having a problem in communication between my computer and a Sony p
Computer is unable to distinguish the device
I know that the reason is the (driver bump), but I do not know what the solution
- The second problem is the camera:
There are crippling in photography in natural light. But the problem in normal lighting
and When using the flash
The problem is flash sync with the image capture
Where the images look as if it is taken in bad lighting
- The third problem:
After downloading the new version of (Android) 4.1
I can no longer browse photos through (Album)
Everything that appears when you open it is a black screen
Seems that the images are there. When I touch the black area and then (menu) and then (edit) picture shows
This problem did not exist before the update
Thank you for all
2 REPLIES 2
Alexander1
I suggest that you clear data for camera, album and media storage. Go to settings > apps > the tab "all" > camera/album/media storage > clear data. Then restart your phone by press and hold the power button and the volume up button at the same time until the phone vibrates.
When it comes to the connection problem I recommend that you take a look at this thread:
http://talk.sonymobile.com/message/328564#328564
yassoor
thank you alexander
the ( Album problem ) ... had been solved by reparing my device
but the camera problem did't solved tell now
