I am having trouble with my WiFi connection. The WiFi doesn't turn off once its turned on. It stays connected with the network even if the network is not in range anymore. I can't turn off my wifi, and it gets struck with the wifi connection and goes no connection. Everytime i had to turn off my phone and then connect to the wifi for my connection. Please help with the issue.
I suggest that you try to run a software reinstall using SUS.
If the problem still remains you should contact your local support team, to have the phone examined and fixed at an repair center.
Johan, are you a bot ? You should know by now from all posted on this board that this behaviour will NOT be fixed by reinstalling the rom, and that it's not a hardware issue. It's a well known bug in the current rom which sony seem unable to fix.
Simply rehashing these 2 magic 'solutions' (which don't solve anything) is completely useless.
