I have tried to update my software for Xperia T3 and when i finished the process of pressing the Press Volume Down/Connect The Usb, it told me that i had failed to update the software because of error in connectivity. My phone was off and now it cannot start or restart. I have tried topress Volume Up and Power but its not responding. I have placed it on charger and its not showing the charging light.
Help please bacause i am stuck right now:smileysad:
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
