Software Problems with Sony Xperia Z
JackWalsh1
My Sony xperia z's sound isnt working. No sound comes out of the internal speakers no matter what app I'm using. But I can use speakers, headphones etc. I can make phone calls and I can hear the person at the other end but cannot hear it ringing. So I don't think there's a problem with the hardware I think it is a software issue since I CAN hear the other end of phone calls. Also my front camera has also decided not to work at all. I am running kit kat 4.4.4. I don't want to have to root the phone anyone know a solution? please.
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
