sms vibrate notification not working
Need help,
My sms vibrate notification is not working even my vibrate notification in both sound setting and sms is turned on
It only vibrates when the sound if off, but the setting in the vibrate is set to 'always'
On call, it always vibrate, the only problem is when receiving an sms when the sound is on.
13 REPLIES 13
turn off your phone -> take the battery out -> press and hold the power button for 5 seconds -> put the battery back on -> turn it on and check again
if not
then go to settings -> privacy -> settings reset
(this will delete passwords and other settings)
if that doesn't solve the issue then
backup everything and then repair your phone with Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
My Phone Explorer
https://market.android.com/details?id=com.fjsoft.myphoneexplorer.client&hl=en
http://www.fjsoft.at/en/
An easier way to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
I forgot to ask, are you using
1) task killer?
or
2) antivirus (mcafee)?
or
3) juice/battery defender?
if you are, that might be the cause of the issues, they cause more harm that they help, remember you don't need an antivirus
No luck on the first step.
Im using avg pro antivirus, missed call and audio manager(but deleted since I thought this was the app causing the problem)
it won't hurt to repair your phone, btw go to settings -> about phone
which android version and build number do you have?
Thanks, ill have it checked later, ill inform later what happens.
Anyway, my android version is 2.3.4 and my build is 4.0.2.A.0.42
This is the latest update
Xperia Play 2.3.4 build number 4.0.2.A.0.62
http://talk.sonyericsson.com/thread/29378
anybody else who can help me? I'm currently updating my phone, but the download speed is very slow..
hope this works.
