Smartwatch 3 band/wrist size help
JD9905
I am very close to ordering one of these watches but I am hesitant because of the one size fits most band that is on the watch.
I don't have the largest wrists, but my wrists measure 7 3/4 inches.
I've searched high and low on the net and haven't found any sizing information. I also went to a Verizon Store to try the floor model on, but they don't have one on display, and I would have to buy one, and then if it dosen't fit, I can later return and wait for a refund.
Any help would be great.
Thanks Jason
7 REPLIES 7
Jake-SonyXperia
Hi JD9905,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I suggest you give Sony Mobile from within your region, they may be able to advise where you can go to see the device before purchase.
I hope this helps.
JD9905
Thanks, I sent an email and will hopefully hear back soon.
Thanks again,
Jason
Jake-SonyXperia
No problem, I hope you get to check the device before purchase Slightly_smiling_Face
JonC1
Hi JD9905
My wrist size is roughly 7 1/2 inches, and I have my SW3 strap on the 2nd-but-last hole which allows my little finger to freely move under the point where the strap meets the watch.  I tried measuring the inside circumference of the strap whilst on it's largest position and it was 8 inches.
I'll try to add pictures later today (12th Nov)
JD9905
Thanks for the info JonC, pics would be great to help push me over the edge and buy one.
Thanks Jason
JonC1
See if these help:
This one shows the inside measurement; there was a bit of slack not seen here so the max inside measurement is 8 inches
This photo shows the possible strap adjustment at max
Just to prove it is a SW3...  And yes, I took these in my kitchen!
JD9905
I'll bite the bullet and pick one up, thanks for the pictures.
