Hello
I love that you can use smartwatch2 and runtastic pro. But the display of the watch is set to two seconds is a big problem while running because you do not have time to be pressing buttons.
regards
There are no settings for the time the display should be active, but it should be more than two seconds. Is it only on for two seconds when you open settings for example? Or do you only experience this when using this application?
If you only experience this when using Runtastic Pro, I suggest that you contact the developer of this application.
