Hi SONY;
I just got my SmartBand. But I'm curious about few things ...
1) I'm right-handed, so which arm should I wear the SmartBand?? (I guess that makes a difference, right?? )
2) Er... but on my left, I already got SmartWatch... = = But of course I can change..
3) Which direction should I (or we) wear the SmartBand?? The button facing front or yourself?
4) Do I need to make SmartBand really tight and fit my wrist? or even loss will do?
I guess these things release affect the detection.
Please kindly advise.
Thanks a lot!
Regards,
@blackmagic wrote:
http://userguide.sonymobile.com/referrer.php?region=global-en&product=smartband-swr10#!Preparing-to-...
Follow Documents
I guess he/she is having the same problem with me..
We want to hear official wearing instruction/suggestion.
Because the way you wear it must have something to do with the sensor.
The document only teach you how to setup. It does not teach you wearing instruction/suggestion.
So, er.....
No one can help??
to have the most accurate readings, fitness trackers should be worn on your non dominant side.
so if you are right handed, wear on left and vice versa. The goal is to eliminate as much arm swing as possible, and your dominant hand moves more than it's less dominant companion.
Actually, it does mention wearing instructions. In line #1 of the introduction, it states that the SB is designed to be worn on the dominant wrist, not the non-dominant wrist.
-Toddler
