As it turned out we all have problems with this device,especially after the last firmware update that literally wasted it.So i will briefly make a noble firmware suggestion to Sony in order to rectify and stand up our expectations!
a)APT-X support
b)Streaming audio fix (VERY IMPORTANT)
c)Bluetooth stability (VERY IMPORTANT)
d)Reach contacts app
e)Voice dial function
f)Radio preset saving
*Please have these in mind for the next firmware and very important..fix the VERY IMPORTAN issues at least to function properly!
Thanks for the feedback!
The audio problem will be fixed in the next update but I'm not aware of any problem with the bluetooth stability. If you're having problems with the bluetooth connection dropping i recommend that you try it with another phone and/or contact a local service location for further investigation.
I fixed your topic as your caps lock seems to have been stuck.
I have a list too.
I have .D firmware, because .E firmware is unusable for my Xperia SL, it restarts by itself, lags and stutters.
My Feature(s) wish list
My Application(s) wish list
Please Fix the firmware, and features of MW1
I only have one wish! Cant belive there is no EQ setting in MP3 player at this beautiful headset!
Im not always using my phone to listen to music were I can adjust this.
Please fix an EQ!
FIRST OF ALL,
Can You make the firmware downgreadeable? Some people say the earlier versions were working better for them...
Radio
- preset storage for the radio
Music Playback
- Podcast folder in list with possible playback speed option
- Audiobook folder with possible playback speed option , Audible compatability would be good
- Folder browing for files on the sd card
- Intelligent fast forward - by that i mean FF that speeds up the longer you hold the button down
- Time remaining/time played options for SD card music playback
- Gapless playback
Other
- Alarms
- ability to cancel the low battery warning
- change the volume of the disconnection sounds
- prompt to save current position on a playlist
- make the m3u format that the mw1 understands cross OS compatible
collated from my 2012 Wish list
Hi, I agree with some of the wishes.
Radio:
Firmware language:
- Portuguese_Brazil (please, if you need some contribution ask me, but include that)
Thx
