Hello,
on my Xperia Z, Smart Connect thinks that the headset are connected, while they're not, so I cannot hear and be heard when doing regular calls !
when I put on hte headset, it works fine.
I uninstalled smartconnect updates, reset the phone, in vain.
any idea please ?
Have you also tried to clean the 3.5mm input of any dirt? What about settings-apps-all,smart connect and clear data?
@alexdon wrote:Have you also tried to clean the 3.5mm input of any dirt? What about settings-apps-all,smart connect and clear data?
Thank you Alexdon for your reply
I did clean the dirt (if any)
I did clear the data, cache, uninstall updates, disable, enable ... SMART CONNECT .. in vain
I rebooted in safe mode and still have the same problem
Smartconnect still thinks the headset is on
could it be the connector damaged ?
@uliwooly wrote:
Boot on safe mode and report back
Try what uli suggested. There is also the option to quickly plug/unplug the headset while in a call/while listening to music.
Gentlemen,
Thank you for all your advices, it DID NOT work for me, my phone still things the headset is plugged in
Please do not create duplicate account,which one will you use?
And to be on topic, you may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
