Can you check if the same occurs in safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Are you using the preloaded messaging app or a third party app? Do you have a taskiller or antivirus? do you have a LOT of messages stored on the (messaging) app?
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Don't forget to backup
