Hi! My z3 compact usually charge the 60% of the batery power in 30 minutes, but now in the last 3 charges it takes like 1 hour to charge de 40% of the batery, I always used the regular charger model: ep880 . what problem could be happening?
It can be that an app or more are using phone resources in the background, consuming battery even when idle. Or it can be a physical issue when the USB cable gets oxidized from aging.
Try to use another USB cable or other chargers if possible, if it still charging slowly, consider performing a software repair using PC Companion.
