Slow Charging Dock DK48 Xperia Z3 Compact
agusv97
Hello everybody,
I recently bought an magnetic charger (DK48) for my Z3C. Today I tried it out and it's charging really slow.
I used the app Ampere to measure it and this are the results:
With 1.5A Sony original cable: 1000mA
With 1.5A Sony original cable and dock: 80mA
With 2A Samsung Tab2 original cable: 900mA
With 2A Samsung Tab2 original cable and dock: 170mA
It shouldn't be that slow. I have read over the Internet that charging the phone in the dock with the phone turned off charges like it should, but haven't tried it out. Nevertheless, I shouldn't need to turn it off to charge it.
Maybe the dock needing 1.8A and the Sony charger giving 1.5A have something to do, but I don't know. And i think that using the Samsung 2A should have solved it
12 REPLIES 12
Kuba5262
I use dk48 and can't see any problem with time of charging with stock ep800 charger 1500 mA. The label says that 1800mA may in&out dk48
agusv97
Thanks for the reply Kuba5262. Well, I´ve found some differences between  your charger and mine. Do you think I've been scammed?? The differences are highlighted in the picture.
Also, I've read that some people started having charging problems with the dock after Lollipop upgrade.
Kuba5262
Maybe you have another version from different manufacturer or product is dedicated to different region. I'm not a specialist and I don't know what means these missing logos. For sure mine dk is newer
agusv97
I hope that is just that. Also I've been told that maybe I received a refurbished phone. Maybe that has something to do. I'll go to a Sony store today maybe to ask, perhaps they know something.
Why do you say your dk is newer? And thanks for the replies, they help a lot, really
Last night I tried charging it overnight with the dock and the phone turned off. It charged from 21% to 69% in 6hs 45min approx. So... Nothing changed
Kuba5262
There is production date at white label
Yours is 14W31 which means week 31 of 2014
Mine is 15W04 - 4th week 2015
Try to use another charger
Check clarity phone's and docking charging sockets
How is your battery life after charging in dk ?
regards
agusv97
Oh, I didn't knew that thing about the date. Thanks for the info!
I'm not at home right now so I can't test another charger with the dock or check the dock sockets.
So far battery life has been normal. I spent like 30min surfing the forums and another 10min in Whatsapp and Instagram this morning while on the bus (using 3G) and lost about 10% of the battery. Since that (1 hour and 40min ago) I've only lost 1%
agusv97
Well... Maybe it's not normal. Battery indicator has been really weird. I use the phone, battery indicator works fine, but then it freezes. It was stuck at 51% for like the last 3 hours, even using the phone for surfing the Web with 3G for some time. And I've just rebooted the phone to see if the battery level drops and it has dropped to 48%. Also, the phone got really hot after rebooting it
Kuba5262
Try software repair after full charge (is without dk charging normal?) you'll find this option in Sony companion
agusv97
Do you mean how long does it take to charge o how the phone behaves after charging? If it's the first option then it's ok, using the wall adapter the phone charges as it should.
Is repair using pc companion the same as doing a factory reset? Because companion keeps asking me to update to lollipop 5.1 and I don't want to because of all the problems regarding battery life on that version
