Hello everybody,
I have a problem with my skype which works with errors. I tried to uninstall and install it many times and there is still some records in android system which dont allow skype to work from blank page like installed first time.
Is there any application which I can use to remove all records about skype in the system and install skype like new?
I tried Root Browser and many uninstallers but they cant help.
what kind of errors or problems do you have? since removing the app actually wipes the app data to so secondly make sure you remove the skype account in settings under accounts if there is one and then re-add it again after installing skype again by logining that way it will add skype account back to list
there is no records of skype in the accounts.
1) when skype is switched on and I try to access application it starts again and again with starting sound but skype was already active before.
2) when skype is On it shows that skype is offline, doesnt matter if invisible, online or away.
3) I switched off all sound notifications and it still keeps screaming on every message
4) and other problems connected to sound notifications.
5) then someone calls I answered on PC - android skype keeps screaming with the call and I have to manually switch off the phone to stop this mess.
odd well that appears to be a problem with skype app then 😕 try contacting skype team instead since i dont think this really has anything todo with xperia z device.
